Techair 11.6" Black Slipcase with Yellow Linit
Quicklinx: C32QWS00 Mfr#: TANZ0305v3
Device Type: Laptop
Type: Case
Device Screen Size: 11.6
Colour: Black
More than 50 In Stock
£10.45 ex VAT
£12.54 inc VAT
If you need a sleeve that gives you a little more than just function, then the neoprene sleeve fits perfectly. Your laptop is happily protected, easily fits into other bags, or you can show it off solo. Now that's function with emotion.
  • Durable design
    Crafted from neoprene and textured polyester, this notebook sleeve offers a robust shield against daily wear and tear, ensuring your device remains protected in various conditions.
  • Soft interior
    The faux fur lining provides a soft bed for your notebook, cushioning it from shocks and scratches, and offering an extra layer of protection.
  • Convenient compatibility
    Designed to accommodate notebooks up to 11.6 inches, this sleeve ensures a snug fit for your device, making it an ideal choice for safeguarding your technology.
techair notebook sleeve
Notebook sleeve
Product Material
Neoprene, textured polyester
31.1 cm x 2.5 cm x 22 cm
153 g
Notebook Compatibility
11.6"
Notebook sleeve
Product Material
31.1 cm
2.5 cm
22 cm
153 g
11.6"
Notebook Compatibility Dimensions
30.5 cm x 21 cm x 3 cm
Closure Type
Zipper
Lining Material
Faux fur
Limited warranty - lifetime
Device Type: Laptop
Type: Case
Colour: Black
Brand: Techair
