The techair TAE4802 notebook carrying case offers a balance of functionality and convenience for on-the-go professionals. With multiple compartments including a front pocket and rear pocket, this case provides storage for your ID card and other essentials, ensuring you stay organized. The durable 900D polyester material adds to its resilience, while the zipper closure provides access to your belongings.
Designed to accommodate notebooks ranging from 11.6 inches to 12.2 inches, this case features dimensions that provide a snug fit for your device. Whether carried by the shoulder strap or the top handle, this case offers versatility to suit your carrying preference, making it an ideal choice for daily commutes or business trips.
- techair - notebook carrying case - work-in
- Product Type
- Notebook carrying case - work-in
- Black
- Product Material
- 900D polyester
- 33.5 cm x 25 cm x 6 cm
- 735 g
- Notebook Compatibility
- 12.2"
- Notebook Supported Sizes
- 11.6" - 12.2" / 29.5 cm - 31.8 cm
- Carrying Strap
- Top carrying handle, shoulder carrying strap
- Limited lifetime warranty
- Product Type
- Product Material
- 900D polyester
- 33.5 cm
- 25 cm
- 6 cm
- 735 g
- 12.2"
- Notebook Compatibility Dimensions
- 31 cm x 21.5 cm x 2.5 cm
- Additional Compartments
- ID card, front pocket, rear pocket
- Carrying Strap
- Closure Type
- Zipper
- Compartments Quantity
- 1
- Black
- Limited warranty: - lifetime
