Ultra-light and slim, this toploader is perfect for those on the move. It is designed for 11.6" laptops with a front pocket to carry documents, cables, leads and accessories. It also features an adjustable and removable shoulder strap.
Protective Design
The foam padding within the case offers robust protection for the notebook, keeping it secure from impacts and ensuring its safety during transport. -
Versatile Carrying Options
Equipped with a shoulder strap and top handles, this case provides multiple ways to carry the notebook, adapting to user preferences and comfort levels. -
Organized Storage
The front pocket allows for organized storage of important accessories, providing quick access to smaller items while keeping everything tidy. -
Durable Materials
Constructed from 500D polyester, this carrying case is built for resilience, making it ideal for daily use and protecting the notebook against external elements.
- techair - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 500D polyester
- 30.5 cm x 5 cm x 21 cm
- 350 g
- Notebook Compatibility
- 11.6"
- Notebook Supported Sizes
- 10" - 11.6" / 25.4 cm - 29.5 cm
- Foam padding
- Carrying Strap
- Shoulder carrying strap, top carrying handles
- Limited lifetime warranty
- Product Type
- Product Material
- 500D polyester
- 30.5 cm
- 5 cm
- 21 cm
- 350 g
- 11.6"
- Notebook Compatibility Dimensions
- 30.5 cm x 21 cm x 3 cm
- Additional Compartments
- Front pocket
- Foam padding
- Carrying Strap
- Black
- Limited warranty: - lifetime
