When you’ve had enough of the same colour…just flip and reverse. The innovative design comes in 10" universal options and it’s available in 3 colour combinations. Designed to fit most 10" tablets, multiple viewing angles, micro fibre material and elastic closure.
Protective design
Crafted from textured polyester, this protective cover offers a durable shield against daily wear and tear. Its elastic band closure ensures the tablet remains secure, while the flip cover design provides easy access when needed. -
Enhanced functionality
Featuring a stand function, this cover allows for hands-free viewing of your 10.1-inch tablet. Whether it's for work presentations or watching videos, the cover supports your tablet in the perfect position. -
Perfect fit
Designed specifically for tablets up to 10.1 inches, the inner dimensions of 27 cm in width, 18.6 cm in depth, and 1.5 cm in height ensure a snug and secure fit, keeping your device protected at all times.
- Tech air Universal - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10.1"
- 27.5 cm x 20.1 cm x 1.5 cm
- 291 g
- Material
- Textured polyester
- Black
- Limited lifetime warranty
- 27.5 cm
- 20.1 cm
- 1.5 cm
- 291 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10.1"
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Elastic band closure
- Inner Dimensions
- 27 cm x 18.6 cm x 1.5 cm
- Cover Features
- Stand function
- Lifetime
