Impact protection
Rest assured with 16 ft. impact protection, thanks to the lab-tested materials and design innovations that protect your device with every fall. -
FlexShock
FlexShock is an advanced material technology that absorbs impact like no other. It takes the heat produced by the force from impact and reforms your case structure, drop after drop. -
Waste responsible innovation
With the innovative bio-spice formula, over 95% of this case breaks down into the earth once you're finished with it, leaving no trace of microplastics.
 - Tech21 Evo Lite - back cover for mobile phone
- Product Type
 - Back cover for mobile phone
 - 11 cm x 20.9 cm x 2.1 cm
 - 41 g
 - Clear
 - 1-year warranty
- Designed For
 - Samsung Galaxy A33 5G
 - 11 cm
 - 20.9 cm
 - 2.1 cm
 - 41 g
 - Clear
Carrying Case
 - Protective cover
- Recommended Use
 - For mobile phone
- Protection
 - Drop protection, camera protection, impact-absorbent
- Cover Type
 - Back cover
 - Military-grade protection
- Max Height of Drop Protection
 - 4.88 m
 - Limited warranty - 1 year
- Designed For
