Visual masterpiece
TCL Mini LED is a visual masterpiece that presents astonishingly vivid visuals with lifelike colours and an ultra-high contrast ratio. It also features higher peak brightness, a wider colour gamut, a larger screen size, and a longer lifespan, making it a leading-edge display technology.
Colour perfection
Utilizing Quantum Dot technology, it unveils over 1,000,000,000 hues of vibrant and precise colours, providing a wider color volume of up to 96% according to the DCI-P3 standard. Immerse yourself in a kaleidoscope of colours, where every shade comes to life with unmatched brilliance and depth.
Stunning HDR whatever the source
There are a lot of ways to get the best HDR picture quality on TV: HDR10, HDR HLG, HDR10+ , HDR DOLBY VISION and DOLBY VISION IQ. This TCL TV supports them all!
Alexa lets your voice control your world
Amazon Alexa lives in the cloud and is always getting smarter. Ask Alexa to play music, hear the news, check weather, adjust TV volume, change TV channel, control your smart home, and more. *Alexa compatibility allow you to use your Amazon Alexa devices, including the Amazon Echo, Echo Dot, Echo Show, Echo Spot, and Echo Plus, to control your TV.
Connect the world through Google Meet
Effortlessly make one-to-one call, or join group calls with Google's video chat App. Send notes, voice or video memos, etc.
Stay in command with Google TV
Google TV's hands-free voice controls provide complete flexibility. Without leaving your chair, you can choose content, launch apps, turn on your set, switch inputs, search for movies, and much more. It's simple, user-friendly, and incredibly convenient. *You can enable or disable voice control by switching on and off the dedicated microphone switch at the bottom part of your TV.
- TCL 50C805K LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- Connectivity
- Wi-Fi, LAN, Bluetooth
- Image Aspect Ratio
- 16:9
- USB
- Included Accessories
- Remote control
- Product Type
- HDR Capable
- TV Tuner Presence
- Video Interface
- HDMI
Display
- Display Format
- 4K UHD (2160p)
- 16:9
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- VESA Compatibility
Media Player
- USB Port
Remote Control
- Remote control
Network & Internet Multimedia
- Connectivity
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Power Device
- Power supply
