Over a billion colours A TV that can display a broader range of colours up to 93% according to the DCI-P3 standard. It's like peering into a kaleidoscope and exploring an endless world of colours.
4K HDR PRO: vivid accurate colors and finest details
The latest standard for UHD content is High Dynamic Range. HDR PRO provides a superior High Dynamic Range experience with great contrast, shadow detail and vivid accurate colors. Experience incredible picture detail as the film makers intended. The picture you see is as detailed as it is in the real world. Dive further into the depth and detail! On TCL TV's, 4K HDR PRO combined with quantum dot provides a superior High Dynamic Range (HDR) experience delivering accurate colors and finest details. -
Motion Clarity for smooth picture and improved motion
On fast moving actions, you don't want to miss a detail. MEMC TCL's proprietary software algorithm steps up to the plate while you're watching sports or fast-paced shows or movies. Helping reduce motion display blur and keeping motion trails to a minimum. Your viewing experience will always be crystal clear, whatever the source is 50 Hz or 60 Hz. -
Stunning HDR whatever the source
There are a lot of ways to get the best 4K HDR picture quality on TV: HDR10, HDR HLG, HDR10+, HDR DOLBY VISION. There are a lot of ways to get the best 4K HDR picture quality on TV: HDR10, HDR HLG, HDR10+, HDR DOLBY VISION. This TCL TV supports them all! Make sure you can Fully use the maximum capacity of your 4K HDR TV: whatever you enjoy Dolby Vision contents on Netflix, Disney+ or HDR 10+ contents on Amazon Prime Video, this 4K HDR TCL TV will always support the best format. -
Your optimized gaming experience
For gamers, a responsive TV is just as important as one with a good picture. With HDMI, and ALLM, you'll experience lowest latency and the best picture settings for gaming, automatically. -
120 Hz game accelerator for a smooth gaming experience
For real gamers, a smooth and responsive screen is far more important than resolution. With TCL's latest technology of 120 Hz DLG (Dual Line Gate), the content auto-adjustment function brings a higher refresh rate and a lower latency. You're just a touch away from a far more seamless gaming experience. On C64 Series, 120 Hz refresh rate is achieved via unique algorithms and TCL technology. Game resolution is automatically set to Full HD to allow 120 images per second. A smooth image for latest 120 Hz game console generations. -
Immersive, moving audio flows all around you
Sound has never sounded this good. Feel a deeper connection to the stories and music you love with sound that moves all around you with breathkaing realism. -
Premium and elegant frameless design
No frame on the front for a bigger screen and more picture that you love. -
Elegant adjustable dual stand position
Elegant and smart: the bezeless luxury design of TCL C64 Series comes with an adjustable dual position stand allowing to place a TCL sound bar or fit this large screen TV on any surface at home. Elegance meets QLED performance and technology in a perfect harmony.
- TCL 50C645K C64K Series - 50" Class (50" viewable) LED-backlit LCD TV - QLED - 4K
- Product Type
- LED-backlit LCD TV - QLED - Smart TV
- Diagonal Class
- 50"
- Diagonal Size
- 50"
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 2160/60p
- HDR Format
- HDR10, HDR10+, Dolby Vision, HLG10
- HDR Technology
- Dolby Vision, HDR 10, Hybrid Log-Gamma (HLG), 4K HDR Pro, HDR 10+
- Frame Rate & Enhancement Technology
- 120 Hz Frame Rate, 3100 Picture Performance Index
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- LED backlight - Quantum Dot technology
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Analogue TV Tuner
- NTSC, PAL, SECAM
- Internet Streaming Services
- Netflix, YouTube, Freeview Play, Chromecast, Amazon Prime Video, Disney+, HbbTV 2.0.2
- Multi-channel Preview
- Picture-and-text (PAT)
- Picture Enhancements
- Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Colour, MEMC, 93% DCI-P3 colour gamut, AiPQ 3.0 engine
- Speaker System
- 2 speakers
- Sound Effects
- DTS Virtual:X
- Intelligent Assistant
- Google Assistant, Alexa (not available for some languages and countries)
- USB
- Included Accessories
- TCL RC833 remote control
- Voltage
- AC 220-240 V (50 Hz)
- Energy Class
- Class G
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 112.2 cm x 8 cm x 64.8 cm
- 9 kg
- 2-year warranty
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Power Consumption SDR (On mode)
- 68 kWh/1000h
- Power Consumption HDR (On mode)
- 113 kWh/1000h
- Diagonal Class
- 50"
- Diagonal Size
- 50"
- Series
- C64K Series
- Platform
- Android TV
- Operating System
- Android TV 11
- HDR Capable
- HDR Format
- HDR Technology
- TV Tuner Presence
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Modes
- Sports mode
- Design
- Ultra Slim Bezel
- Dimensions
- Without stand
- 112.2 cm
- 8 cm
- 64.8 cm
- 9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Display Menu Language
- Multilingual
- Sleep timer, Freesync, AI Technology, Game bar, Game Master, Auto Channel Search, 20P and 2P colour calibration
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Y-Shape
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
TV Tuner
- Analogue TV Tuner
- NTSC, PAL, SECAM
- Conditional Access
- Common Interface Plus (CI+) slot
- Reception System
- NTSC, PAL-L, SECAM-I, SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
Digital TV Tuner
- Digital TV Tuner
- Digital TV Service
- HbbTV
- MPEG Profiles and Levels
- MPEG2/H.264, H.265
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM
- 2160/60p
- Teletext
- Electronic Programme Guide
- 8-day EPG
Media Player
- Supported Video Formats
- MPEG-4, WMV, AVI, MKV, TS, H.264, WebM, MPG, H.265, VP9, AV1
- Supported Audio Formats
- MP3, WMA
- Supported Pictures Formats
- BMP, JPG, PNG, HEIF
- USB Port
- USB Ports Qty
- 1
- Configuration
- Quad-Core - 2 GB
Remote Control
- Remote control
- Remote Control Model
- TCL RC833
- Battery Included
- Voice control, smart phone remote support
Audio System
- Digital Audio Format
- Dolby True HD digital output, Dolby Atmos, Dolby AC-4 output
- Sound Effects
- DTS Virtual:X
- Equaliser
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Digital noise reduction, voice recognition, Automatic Volume Control (AVC), Enhanced Audio Return Channel (eARC), auto low latency mode (ALLM)
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi Protocol
- 802.11g, 802.11n, 802.11ac
- Connect & Share
- USB Human Interface Device (HID), Bluetooth Human Interface Device (HID), T-cast
- Application Store
- Google Play
- DLNA
- Connector Type
- Digital audio input (optical) , 3 x HDMI , Headphones , Aerial input , LAN , Aerial input , USB 3.0
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Google Assistant, Alexa ready (not available for some languages and countries)
- HDCP 2.3, TUV Rheinland Low Blue Light (Software Solution)
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Auto On/Off
- Limited warranty - 2 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 112.2 cm x 8 cm x 64.8 cm x 9 kg , Panel with stand - 112.2 cm x 26.5 cm x 70 cm x 9.1 kg , Stand - 26.5 cm
- Width (Shipping)
- 126 cm
- Depth (Shipping)
- 12.8 cm
- Height (Shipping)
- 77.4 cm
- Weight (Shipping)
- 12.5 kg
