TBS6285 the successor of the TBS6284, which is a Quad tuner PCI-Express interface DVB-T2/T TV Tuner Card for watching or recording four different channels from four different frequencies simultaneously.
TBS 6285 can be used as a digital video recorder for recording digital terrestrial TV programs with full HDTV support. With the Time-shifting function, it also enables you to pause a live broadcast and continue from where you left. This DVB T2 PC TV card is ready with windows BDA driver and Linux driver.
It's ideal for watching UK Freeview SD and HD channels on your desktop PC. Please ensure you can receive the Digital Terrestrial Television (DVB-T, DVB-T2, Freeview) service in your region. The TBS 6285 requires you use a high-gain roof aerial to enable and enjoy reliable digital television reception throughout the UK.
Main Features:
Low profile design
Quad channel receiving simultaneously
Both DVB-T2 and DVB-T are supported
High-definition video, real-Time and scheduled video recording
High sensitivity DVB-T2 Quad Tuner for the best digital TV reception
Windows BDA driver and Linux Driver ready
Specifications:
Receiving channel: VHF band and UHF band
Channel bandwidth: 6, 7, 8 MHz
DVB-T2/ T modulation type: QPSK, 16QAM, 64QAM, 256QAM
FFT mode: 1K, 2K, 4K, 8K, 16K, 32K
Code rate: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 7/8
Guard internal:1/4, 1/8, 1/16, 1/32, 1/64, 1/128, 19/128, 19/256
Intermediate frequency
IF mode: low IF
Center IF Frequency: 3 ~ 5 MHz
Note: default 4MHz
RF-Input impedance 75O (IEC-DIN female)
RF-Output impedance 75O (IEC-DIN male)
TV card size: 130x68.6mm (length x height)
TV card weight: 84g
Power consumption: 6.7 - 9 W
System Requirements:
Windows 2000/XP/Vista/7 /8 or Linux
Pentium 4 2.0 GHz, Pentium M 1.3 GHz
For HDTV: 2.6 GHz multi core processor
Hard disk with min. 1 GB free capacity
Sound and graphics card with support for DirectX 9 or higher
Available PCI Express x1, x4, x8 or x16 slot
CD/DVD drive for software installation
Package Contains:
1 x PCI-E DVB-T2 quad tuner card
1x Remote control
1x IR receiver
1x Aerial
1x Software CD
1x Low profile bracket
1x F connector
