Targus Versavu iPad Air and Air 2 Tablet Case - Black
Quicklinx: BM8VWS00 Mfr#: THZ597EU
For a slim iPad smart case, look no further than the Targus Versavu 360-degree iPad case. The perfect fit cradle holds your iPad securely, while the deep foam grooves provide angles for comfortable viewing and typing. Our 360-rotating technology allows you to seamlessly switch from landscape to portrait effortlessly. Made of a polyurethane material, the slim design keeps your device clean and protected while easily traveling with you. The discreet cord closure makes sure that your device stays in place when you’re on the move. The Versavu 360° fits conveniently in your bag, so you’ll never have to worry about your iPad weighing you down. Recognised by the Independent newspaper as the best buy tablet case. Read the review.
Targus VersaVu 360° Rotating - flip cover for tablet
Flip cover for tablet
18 cm x 2.5 cm x 24.5 cm
300 g
Europe
Material
Polyurethane
18 cm
2.5 cm
24.5 cm
300 g
Material
Polyurethane
Europe
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Flip cover
Camera lens cutout, port cut-outs, adjustable viewing angles, buttons cutout
Cover Features
Stand function
2 years
