Targus USB-C Dual HDMI 4K Docking Station
Quicklinx: GW53WS00 Mfr#: DOCK423EU
More than 50 In Stock
£79.60 ex VAT
£95.52 inc VAT
Turn your laptop into a dual video workstation with the compact USB Type-C Alt Mode Dual HDMI 4K docking station with 100W PD pass-through. Connect your USB Type-C enabled devices to two HDMI monitors, while also connecting to a Gigabit Ethernet network and plugging in your key peripherals, like mice, keyboards, flash drives, or hard drives, into the USB Type-A ports.
Plus, access your data with the SD and microSD card reader/writer. You can even keep your laptop charged and powered by connecting the laptop USB Type-C power adapter to the USB Type-C port on the dock. This dock also provides transfer speeds up to 5Gbps per port. It supports up to 100W (20V/5A) maximum charging. Compact and lightweight, it's easy to take it along with you anywhere you go.
  • 4K UHD Display
    Whether you want to run a presentation on a larger display or use an external display, this USB-C dock adapts USB-C to dual HDMI displays at up to 4K resolution.
  • Connectivity Made Simple
    Enhance your productivity and connect to more with 2 USB-A 3.2 Gen 1 ports (1 fast-charging).
  • Charge and Power Host Device
    With up to 100W Power Delivery pass-thru, this USB-C to dual HDMI dock allows you to power and charge your USB-C laptop or host simply by connecting the laptop’s power adapter into the USB-C port. Great for laptops with only one USB-C port.
  • Perfectly Portable
    Slim and light, this USB-C dual monitor dock is perfect for the home, office, or anywhere in between. Great for mobile workers or those in hoteling or hot desking environments.
  • Plug and Play Simplicity
    With no need for additional software, this adapter easily attaches to your USB-C Alt. Mode (including Thunderbolt™ 3) host device (i.e., laptop) to convert USB-C to dual HDMI outputs, connect to a wired network, use more peripherals, and transfer data.
Targus - docking station - USB-C / Thunderbolt 3 - 2 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI
15 cm x 10 cm x 3 cm
130 g
Silver
Gigabit Ethernet
Docking station
15 cm
10 cm
3 cm
130 g
Enclosure Colour
Silver
Video
Max Resolution Details
4K - 60 Hz
Gigabit Ethernet
Power Delivery 3.0, USB 3.2 Gen 1, Battery Charging 1.2
Expansion Slots
1 (total) / 1 (free) x microSDXC UHS-I , 1 (total) / 1 (free) x SD Memory Card
2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x network - 1000Base-T - RJ-45
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 17.8 cm
DisplayPort Alt Mode, 100W power delivery, Samsung DeX, HDR support
Plug and Play
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS, Apple iPadOS
Brand: Targus
