Targus USB 3.0 SuperSpeed Multi Monitor Adapter
Quicklinx: BBS0WS00 Mfr#: ACA038EU
Accessory Type: Adapter
£53.41 ex VAT
£64.09 inc VAT
Expand your view and connect your laptop to an external monitor via USB 3.0 SuperSpeed enabling instant connectivity and superb picture quality between your laptop and additional monitor. Choose between extending your desktop onto the secondary monitor to view two different applications at the same time, mirroring your laptop screen, or switching off your laptop screen and using the external monitor as your main screen. The multi monitor adapter offers improved productivity and combined with Targus USB 3.0 SuperSpeed Dual Video Docking Station you can support three external monitors, tripling your view.
  • Enhanced resolution
    Experience crystal-clear visuals with the Targus Multi Monitor Adapter, supporting a maximum output resolution of 2048 x 1152. This feature ensures your displays deliver high-quality images for an immersive viewing experience.
  • Versatile connectivity
    With support for DVI / USB interfaces and compliance with USB 3.0 standards, this adapter offers versatile connectivity options. Whether you're connecting to newer or legacy devices, the adapter ensures compatibility and seamless integration.
  • Durable design
    The Targus Multi Monitor Adapter is designed with high-quality materials and standards to ensure reliability and durability. Its robust construction ensures a stable connection between your devices, enhancing your productivity without interruptions.
Targus Multi Monitor Adapter - adapter - DVI / USB
Cable
Adapter - DVI / USB
Max Output Resolution
2048 x 1152
Europe
Connector
USB Type A - male
Connector (Second End)
DVI-I - female
USB 3.0
Cable Type
Adapter
Interface Supported
DVI / USB
USB 3.0
Europe
Adapters & Converters
2048 x 1152
Connector
9 pin USB Type A - male
24+5 pin combined DVI - female
9.5 cm
6 cm
2 cm
90 g
Brand: Targus
