Targus Urban Explorer Laptop Backpack is your go-to bag Monday through Sunday. The outdoor inspired design features a padded laptop sleeve and room for a tablet, phone, accessories and personal belongings, whether commuting to work or away for the weekend the water repellent material ensures your belongings are protected against the weather. Our unique AIR X FLOW back padding boosts airflow to keep you comfortable and cool. Ideal for cyclists with compression straps which can be tightened to maintain a slim profile and reflective panels help you stay visible in the dark, a discreet whistle on the chest strap also means you can call attention to yourself if you need to.
Ergonomic design
The Targus Urban Explorer backpack is designed with AIR X FLOW back padding and adjustable padded shoulder straps, ensuring comfort during extended wear. Its ergonomic design is complemented by a chest strap for added stability, making it an ideal choice for daily commutes and adventures. -
Ample storage
Featuring a spacious 24-liter capacity, this backpack offers dedicated compartments for a bottle, cellular phone, personal accessories, and a tablet, alongside a padded notebook compartment. It's designed to keep your essentials organized and easily accessible. -
Durable and secure
Crafted from twill polyurethane, the Targus Urban Explorer backpack is not only durable but also water-repellent, protecting your belongings from the elements. Reflective elements enhance visibility in low light conditions, ensuring safety during your travels.
- Targus Urban Explorer - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Grey
- Product Material
- Twill polyurethane
- 30.5 cm x 17 cm x 47 cm
- 910 g
- Notebook Compatibility
- 15.6"
- Reflective elements, water repellent, padded notebook compartment, AIR X FLOW back padding
- Carrying Strap
- Chest strap, adjustable padded shoulder straps
- Limited lifetime warranty
- Product Type
- Product Material
- 30.5 cm
- 17 cm
- 47 cm
- 910 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.7 cm x 26.5 cm x 2.5 cm
- Additional Compartments
- Mobile phone, personal accessories, bottle, tablet
- Carrying Strap
- Ventilated Back
- Ventilated Back Type
- Mesh material
- Capacity
- 24 litres
- Grey
- Limited warranty: - lifetime
