Targus ProTek iPad Case is multi-fit, compatible with iPad 2018/2017, 9.7" iPad Pro & iPad Air 2. Advanced protection for your tablet the shock-absorbing case has a tough outer edge with side & corner protection with access to iPad ports and camera. The engineered case design is easy to grip and water-resistant with a reassuring elastic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
Enhanced durability
Crafted from polycarbonate and thermoplastic polyurethane (TPU), this protective cover offers robust protection against drops, impacts, and everyday wear. Its resilience ensures your tablet remains safeguarded from dirt, dust, and water, making it an ideal companion for on-the-go use. -
Versatile functionality
The Targus Pro-Tek Handheld Folio not only protects your device but also enhances its usability. Featuring an elastic band closure for secure transport, a hand strap for comfortable holding, and a stand function for easy viewing, this flip cover supports a variety of use cases. -
Optimal compatibility
Designed specifically for tablets with a 9.7-inch screen, this cover ensures a perfect fit for your device, providing access to all ports and buttons. The additional compartment for an Apple Pencil adds convenience, keeping your accessories organized and within reach.
- Targus Pro-Tek Handheld Folio - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 9.7"
- 18.5 cm x 1.5 cm x 26 cm
- 330 g
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- Black
- 2-year warranty
- 18.5 cm
- 1.5 cm
- 26 cm
- 330 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Shockproof, dust-resistant, dirt-resistant, impact protection, water-resistant, drop protection, scuff-resistant
- Cover Type
- Flip cover
- Open Type
- Side
- Carrying Strap
- Hand strap
- Closure Type
- Elastic band closure
- Additional Compartments
- Apple Pencil
- Cover Features
- Stand function
- Max Height of Drop Protection
- 1.8 m
- 2 years
