Targus Pro-Tek Handheld Folio Flip cover for iPad 9.7" - Grey
Quicklinx: DYPLWS00 Mfr#: THD483GLZ
Targus ProTek iPad Case is multi-fit, compatible with iPad 2018/2017, 9.7" iPad Pro & iPad Air 2. Advanced protection for your tablet the shock-absorbing case has a tough outer edge with side & corner protection with access to iPad ports and camera. The engineered case design is easy to grip and water-resistant with a reassuring elastic closure to keep your screen protected. Front cover transforms into a stand for infinite viewing angles and a comfortable typing position.
  • Enhanced durability
    Crafted from polycarbonate and thermoplastic polyurethane (TPU), this protective cover offers robust protection against drops, impacts, and everyday wear. Its resilience ensures your tablet remains safeguarded from dirt, dust, and water, making it an ideal companion for on-the-go use.
  • Versatile functionality
    The Targus Pro-Tek Handheld Folio not only protects your device but also enhances its usability. Featuring an elastic band closure for secure transport, a hand strap for comfortable holding, and a stand function for easy viewing, this flip cover supports a variety of use cases.
  • Optimal compatibility
    Designed specifically for tablets with a 9.7-inch screen, this cover ensures a perfect fit for your device, providing access to all ports and buttons. The additional compartment for an Apple Pencil adds convenience, keeping your accessories organized and within reach.
Targus Pro-Tek Handheld Folio - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
9.7"
18.5 cm x 1.5 cm x 26 cm
330 g
Material
Polycarbonate, thermoplastic polyurethane (TPU)
18.5 cm
1.5 cm
26 cm
330 g
Material
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Shockproof, dust-resistant, dirt-resistant, impact protection, water-resistant, drop protection, scuff-resistant
Cover Type
Flip cover
Open Type
Side
Carrying Strap
Hand strap
Closure Type
Elastic band closure
Additional Compartments
Apple Pencil
Cover Features
Stand function
Max Height of Drop Protection
1.8 m
2 years
