Keep your business your business with a Targus Privacy Screen. Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
Enhanced privacy
The Targus Privacy Screen is designed with a +/- 30° visible angle, ensuring that your information remains confidential. Perfect for high-traffic areas or those who value their privacy while working. -
Versatile viewing
Featuring a unique glossy/matte surface finish, this privacy screen offers users the flexibility to choose their preferred viewing experience. Whether you're working under bright lights or prefer a glare-free screen, this product adapts to your needs. -
Eye comfort
With an integrated blue light filter, the Targus Privacy Screen reduces eye strain associated with extended screen time. This feature is essential for users who spend long hours in front of their computer, providing a more comfortable viewing experience. -
Touch compatibility
Designed to be fully functional with touchscreen devices, this privacy screen does not hinder the sensitivity of touch interfaces, allowing for uninterrupted usage of your device's touch capabilities.
- Targus Privacy Screen - display privacy filter - 24" wide
- Product Type
- Display privacy filter
- Installation Type
- Removable
- Display Screen Size Compatibility
- 24" wide
- 52 cm 33 cm
- 110 g
- 2-year warranty
- Product Type
- 24" wide
- 52 cm 33 cm
- 110 g
Display Filter
- Installation Type
- Removable
- Aspect Ratio
- 16:10
- Surface Finish
- Glossy/matte
- Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
- Limited warranty - 2 years
Targus Privacy Screen 24" Widescreen (16:10)
