Targus Privacy Screen 24" Widescreen (16:10)
Quicklinx: BBSRWS00 Mfr#: ASF24WEU
38 In Stock
£82.11 ex VAT
£98.53 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen is designed with a +/- 30° visible angle, ensuring that your information remains confidential. Perfect for high-traffic areas or those who value their privacy while working.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen offers users the flexibility to choose their preferred viewing experience. Whether you're working under bright lights or prefer a glare-free screen, this product adapts to your needs.
  • Eye comfort
    With an integrated blue light filter, the Targus Privacy Screen reduces eye strain associated with extended screen time. This feature is essential for users who spend long hours in front of their computer, providing a more comfortable viewing experience.
  • Touch compatibility
    Designed to be fully functional with touchscreen devices, this privacy screen does not hinder the sensitivity of touch interfaces, allowing for uninterrupted usage of your device's touch capabilities.
Targus Privacy Screen - display privacy filter - 24" wide
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
24" wide
52 cm 33 cm
110 g
24" wide
52 cm 33 cm
110 g
Display Filter
Installation Type
Removable
Aspect Ratio
16:10
Surface Finish
Glossy/matte
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Brand: Targus
