Targus Privacy Screen 23" Widescreen
Quicklinx: B3MWWS00 Mfr#: ASF23W9EU
Accessory Type: Privacy Screen
Hurry, only 2 left in stock!
£47.80 ex VAT
£57.36 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen is designed to protect sensitive information from prying eyes. With a +/- 30° visible angle, it ensures that your data is visible only to you, making it an essential tool for maintaining privacy in public spaces or open office environments.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen offers the flexibility to choose your preferred viewing experience. Whether you're working under bright office lights or in the comfort of your home, you can switch between a glossy or matte finish to reduce glare and reflections.
  • Eye comfort
    With an integrated blue light filter, the Targus Privacy Screen not only protects your privacy but also reduces eye strain associated with prolonged screen time. This feature is especially beneficial for users who spend extensive hours in front of their computer, providing a more comfortable viewing experience.
Targus Privacy Screen - display privacy filter - 23" wide
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
23" wide
51 cm x 0.1 cm x 29 cm
100 g
Dell P2312H, S2330MX, ST2320L; UltraSharp U2312HM
23" wide
51 cm - 0.1 cm - 29 cm
100 g
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Touch screen compatible, blue light filter, anti-glare, anti-reflective, +/- 30° visible angle
Dell P2312H, S2330MX, ST2320L , Dell UltraSharp U2312HM
Brand: Targus
