Targus Privacy Screen 22" Widescreen (16:9)
Quicklinx: BBSNWS00 Mfr#: ASF22W9EU
Hurry, only 2 left in stock!
£72.26 ex VAT
£86.71 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen is designed to protect sensitive information from prying eyes. With a +/- 30° visible angle, it ensures that your data is visible only to you, making it an essential tool for maintaining privacy in public spaces or open office environments.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen offers the flexibility to choose your preferred viewing experience. Whether you're working under bright office lights or in the comfort of your home, you can switch between a glossy or matte finish to reduce glare and reflections.
  • Eye comfort
    Equipped with an advanced blue light filter, the Targus Privacy Screen minimizes eye strain during long working hours. This feature, combined with its anti-glare and anti-reflective properties, ensures a comfortable viewing experience, even under various lighting conditions.
  • Touchscreen compatibility
    Designed to seamlessly integrate with your 22" wide display, this privacy screen does not compromise on touchscreen functionality. Its precise engineering allows for full touchscreen compatibility, ensuring that you can navigate your device with ease.
  • Easy installation
    The removable design of the Targus Privacy Screen offers a hassle-free installation process. It allows for quick attachment and removal, making it an ideal solution for individuals who are always on-the-go or for those who need to frequently share their screen with others.
Targus Privacy Screen - display privacy filter - 22" wide
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
22" wide
48 cm 27 cm
80 g
Dell E2210C, E2311H
22" wide
48 cm 27 cm
80 g
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Touch screen compatible, blue light filter, anti-glare, anti-reflective, +/- 30° visible angle
Dell E2210C, E2311H
Brand: Targus
