Targus Privacy Screen 22" Widescreen (16:10) - Notebook Privacy Filter
Quicklinx: B8WBWS00 Mfr#: ASF220WEU
Accessory Type: Privacy Screen
£40.87 ex VAT
£49.04 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen ensures your data remains confidential with its +/- 30° visible angle, making it difficult for others to view your screen from the side.
  • Versatile viewing
    Featuring a glossy/matte surface finish, this privacy screen offers the flexibility to choose your preferred viewing experience while reducing glare and reflections.
  • Eye comfort
    With an anti-reflective coating and blue light filter, the Targus Privacy Screen minimizes eye strain during extended use, making it ideal for both work and leisure.
  • Seamless compatibility
    Designed to fit 22" wide screens, this display privacy filter is compatible with a wide range of monitors, ensuring a perfect fit for your device.
  • Touchscreen functionality
    Despite its protective features, the Targus Privacy Screen remains fully touchscreen compatible, ensuring uninterrupted use of your device.
Targus Privacy Screen - display privacy filter - 22" wide
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
22" wide
47.3 cm 29.5 cm
90 g
Dell E2210, E2213, P2213
22" wide
47.3 cm 29.5 cm
90 g
Display Filter
Installation Type
Removable
Aspect Ratio
16:10
Surface Finish
Glossy/matte
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Brand: Targus
