Targus Privacy Screen 15.6" Widescreen (16:9) - Notebook privacy filter - black, transparent
Quicklinx: 7QKMWS00 Mfr#: ASF156W9EU
Accessory Type: Privacy Screen
Hurry, only 1 left in stock!
£28.93 ex VAT
£34.71 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen ensures your data remains confidential with its +/- 30° visible angle, making it difficult for others to view your screen from the side.
  • Eye comfort
    Equipped with anti-glare and anti-reflective features, along with a blue light filter, this privacy screen reduces eye strain and makes viewing your screen more comfortable in various lighting conditions.
  • Versatile compatibility
    Designed to fit 15.6" wide screens, this privacy screen is compatible with a wide range of notebooks, ensuring a perfect fit for your device.
  • Touchscreen functionality
    Despite its protective layers, the Targus Privacy Screen remains fully touchscreen compatible, ensuring uninterrupted touch functionality for your device.
Targus Privacy Screen - notebook privacy filter
Installation Type
Removable
34.5 cm 19.5 cm
40 g
Display Screen Size Compatibility
15.6" wide
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Europe
Dell Inspiron 15, 1545, 1564, 15R, 15z; Latitude E5510, E5510 N-Series, E5530, E6520, E6520 N-Series, E6530; Precision M4500, M4600; Vostro 1540, 3500, 3555, 3560; XPS 15z (L511z)
34.5 cm
19.5 cm
40 g
15.6" wide
Europe
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Limited warranty: - 2 years
Dell Inspiron 15, 1545, 1564, 15R, 15z , Dell Latitude E5510, E5510 N-Series, E5530, E6520, E6520 N-Series, E6530 , Dell Precision M4500, M4600 , Dell Vostro 1540, 3500, 3555, 3560 , Dell XPS 15z (L511z)
Brand: Targus
