Targus Privacy Screen 14" Widescreen (16:9)
Quicklinx: BBSBWS00 Mfr#: ASF14W9EU
Hurry, only 3 left in stock!
£40.87 ex VAT
£49.04 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen ensures your data remains confidential with its +/- 30° visible angle, making it difficult for others to view your screen from the side.
  • Versatile viewing
    With both glossy and matte finishes, you can choose the finish that best suits your viewing preferences, whether you're aiming to reduce glare or enhance clarity.
  • Eye comfort
    Equipped with an anti-glare, anti-reflective, and blue light filter, this privacy screen helps reduce eye strain during long working hours, making it ideal for both office and remote work.
  • Touch compatibility
    Designed to be fully functional with touchscreen devices, the Targus Privacy Screen allows you to work efficiently without compromising on privacy or screen responsiveness.
Targus Privacy Screen - notebook privacy filter
Notebook privacy filter
Installation Type
Removable
31 cm 17.5 cm
40 g
Display Screen Size Compatibility
14" wide
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Europe
31 cm
17.5 cm
Thickness
1 mm
40 g
14" wide
Finish
Glossy, matte
Europe
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Limited warranty: - 2 years
Brand: Targus
