Targus Privacy Screen 13.3" Widescreen (16:10) - Notebook privacy filter - black, transparent
Quicklinx: 7NQBWS00 Mfr#: ASF133WEU
Type: Privacy Screen
Device Screen Size: 13.3
£22.54 ex VAT
£27.04 inc VAT
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
Targus Privacy Screen - notebook privacy filter
Installation Type
Removable
28.5 cm 17.8 cm
37 g
Display Screen Size Compatibility
13.3" wide
Anti-glare, anti-reflective, touch screen compatible, blue light filter, +/- 30° visible angle
Europe
Dell Vostro 1320n
28.5 cm
17.8 cm
37 g
13.3" wide
Finish
Glossy, matte
Europe
Display Filter
Installation Type
Removable
Aspect Ratio
16:10
Limited warranty: - 2 years
Dell Vostro 1320n
Brand: Targus
