Targus Notebook Carry Case
Quicklinx: 39VKWS00 Mfr#: CN31
Device Type: Laptop
Type: Bags & Cases
Device Screen Size: [N/A]
Colour: Black
Hurry, only 1 left in stock!
£16.18 ex VAT
£19.41 inc VAT
This beautiful collection of laptop cases brings a contemporary slant on classic design. Each case has been carefully crafted with a stylish approach to practicality. Constructed from quality materials, each case features a protective padded laptop section so you can be sure that your laptop is safe. Carrying is made comfortable with a cushioned shoulder pad. The length of the shoulder strap is adjustable and the strap can be removed completely if desired. The trolley strap on the back of the case allows you to securely attach the case to luggage for easy transportation. Keeping belongings organised is easy with a selection of sized pockets designed for convenience, easily accessible in front zip down section.
Targus Classic Clamshell - notebook carrying case
Notebook carrying case
Product Material
Polyester
39 cm x 9 cm x 36 cm
650 g
Notebook Compatibility
16"
Notebook Supported Sizes
15" - 16" / 38.1 cm - 40.6 cm
Padded notebook compartment
Carrying Strap
Top carrying handles, removable/adjustable padded shoulder strap
Product Material
Polyester
39 cm
9 cm
36 cm
650 g
16"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Front zippered pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Device Type: Laptop
Type: Bags & Cases
Colour: Black
Brand: Targus
