Targus Multimedia USB Presenter
Quicklinx: 76HYWS00 Mfr#: AMP09EU
Accessory Type: Remote Control
£37.00 ex VAT
£44.40 inc VAT
Don’t fumble around with wires or fuss over the computer; present like a professional and control your computer remotely, using just one device – the Targus Multi Media Presentation Remote with Cursor Control. Thanks to the remote’s 2.4GHz cordless technology, you can access programmes, launch the internet, adjust volumes and playmusic and videos, all fromup to 15metres away. The Targus MultiMedia Presentation Remote will give you the freedom to concentrate on your Microsoft PowerPoint™or Apple Keynote™ presentation, without having to worry aboutmakingmistakes – the system’s patented KeyLock Technology locks non-essential keys,meaning you can’t press them accidentally.Walk around and take the presentation at your own pace. You can even dimthe lights if necessary as the remote has backlit buttons for use in low-light environments. The easy-to-guide and cursor controls will enable you to access your computer and move your presentation along smoothly and efficiently. The mini USB receiver stores neatly inside the remote when it’s not in use for added convenience, so it won’t get lost or damaged. The versatile systemis compatible with Mac, PC and netbooks and you don’t need special drivers or software. Present the professional way with the Targus Multi Media Presentation Remote with Cursor Control.
  • Functionality
    Clear and intuitive layout enables users to open and operate a presentation with ease. Laser pointer makes it easy to highlight presentation content while the back-lit buttons make it easy to present in rooms with low-lighting multimedia.
  • Cursor / volume control button
    Cursor control for remote access to programs; control volume for music and videos remotely, offers a built-in laser pointer to help emphasize or bring attention to important points during presentations.
  • Practical
    Designed to feel natural and comfortable in your hand while presenting.
  • Wireless
    2.4 GHz wireless technology operates up to 15 meters away for added flexibility. A hidden compartment or dock that conveniently stores your USB receiver along with your presenter to keep you on point when you reach your destination.
  • KeyLock technology
    patent pending technology locks non-essential buttons to eliminate accidental button presses.
Targus Multimedia presentation remote control - grey, black
Presentation remote control
Enclosure Colour
Grey, black
12 cm x 3.8 cm x 2.5 cm
70 g
Europe
Radio
Supported Devices
Notebook, personal computer
Wireless Technology
2.4 GHz
Max Operating Distance
15 m
12 cm
3.8 cm
2.5 cm
70 g
Enclosure Colour
Grey, black
Europe
Radio
Wireless Technology
2.4 GHz
Supported Devices
15 m
Built-in laser pointer, back-lit buttons, volume control, KeyLock Technology, Cursor Control
Connector Type
USB (4 PIN USB Type A)
Operating System
MS Windows 7, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.6 - 10.13.3
USB receiver
76HY C2G 2m USB 2.0 A/B Cable - Black In Stock £3.62
Brand: Targus
