The Targus Laser Presentation Remote features a clear and intuitive button layout,making it easy to give presentations. Thanks to its 2.4GHz cordless technology, you’ll be free to move around and control your Microsoft PowerPoint™ or Apple Keynote™presentation remotely, without wires and cords getting in the way. The patent-pending KeyLock™Technology locks non-essential buttons when not needed to help eliminate accidental button presses. The integrated laser pointer allows the presenter to highlight important content while the backlit buttons provide visibility in environments with low lighting. The latest RF 2.4GHz cordless technology works fromup to 15metres away, providing flexibility while presenting in large conference rooms or classrooms. The mini USB receiver stores neatly inside the remote when it’s not in use for added convenience, so it won’t get lost or damaged. Both stylish and functional, the Targus Presentation Remote is your essential tool in achieving seamless presentation results.
Effortless connectivity
Equipped with a 4-pin USB Type-A connector, this presentation remote ensures seamless connectivity with a wide range of devices, making it a versatile tool for any presenter. -
Advanced control features
Featuring KeyLock Technology, backlit buttons, and a built-in laser pointer, this remote offers control and visibility during presentations, enhancing the overall delivery and audience engagement. -
Extended wireless range
With a maximum operating distance of 15 m and utilizing 2.4 GHz wireless technology, presenters can freely move around the room, ensuring dynamic and interactive presentations without the constraints of wires.
- Targus presentation remote control - grey, black
- Presentation remote control
- Enclosure Colour
- Grey, black
- 12 cm x 4 cm x 3 cm
- 50 g
- Localisation
- Europe
- Connectivity Technology
- Radio
- Supported Devices
- Notebook, personal computer
- Wireless Technology
- 2.4 GHz
- Max Operating Distance
- 15 m
- 2-year warranty
- 12 cm
- 4 cm
- 3 cm
- 50 g
- Enclosure Colour
- Grey, black
- Localisation
- Europe
- Radio
- 2.4 GHz
- Supported Devices
- 15 m
- Built-in laser pointer, back-lit buttons, KeyLock Technology
- Connector Type
- USB (4 PIN USB Type A)
- Operating System
- MS Windows 7, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.6 - 10.13.3
- Included Accessories
- USB receiver
- Plug and Play
- Limited warranty - 2 years
Targus LASER PRESENTATION REMOTE
