Heavy Duty. Exclusive Style.
The Impact case is precision tooled and built toresist, designed exclusively using the Targus custom 3D integrated protection system.
Combining advanced engineering with all of the functionality you demand from your tablet, this rugged case has a tough outer edge with shock absorbing qualities which help to protect your deviceagainst everyday drops and dents.
The easy grip design is finished with a water and dirt repellent coating, making the Impact case ideal for use in extreme environments.
