Targus Geolite Plus 12.5-15.6" Backpack - Ocean
Quicklinx: F7PCWS00 Mfr#: TSB96101GL
Device Type: Laptop
Type: Backpack
Device Screen Size: 15.6
£26.07 ex VAT
£31.28 inc VAT
For modern professionals and mobile trendsetters, the new Geolite range blends protection, comfort, and affordability, all in one. A durable mix of material and style offers ample storage capacity in compact, sophisticated designs. Multi-Fit cradle offers a reassuringly snug fit for laptops between 12.5-15.6". The Geolite Plus Multi-Fit Backpack is designed to fit your laptop and your life with flexible dedicated compartment. Dedicated compartment separates laptop from your personal belongings. With the comfort of adjustable shoulder straps, breathable air channel back panel design and convenience of front zippered pockets, this backpack is ideal for business travel and everyday commute.
  • Weather-resistant design
    Crafted with nylon and polyurethane, this backpack offers a weather-resistant feature that protects your devices and documents from the elements, ensuring your essentials stay dry and secure no matter the weather.
  • Comfortable carrying
    Equipped with adjustable padded shoulder straps and a ventilated back made of mesh material, this backpack provides maximum comfort and breathability, making it ideal for extended wear on your daily commute or travel.
  • Spacious and organized
    Featuring a front zippered pocket and additional compartments, the Targus Geolite Plus backpack offers ample space for your 15.6-inch notebook, accessories, and personal items, keeping everything organized and easily accessible.
Targus Geolite Plus - notebook carrying backpack
Notebook carrying backpack
Product Material
Nylon, polyurethane
31 cm x 13.4 cm x 46.4 cm
0.61 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
12.5" - 15.6" / 31.8 cm - 39.6 cm
Weather resistant
Carrying Strap
Adjustable padded shoulder straps
Product Material
Nylon, polyurethane
31 cm
13.4 cm
46.4 cm
0.61 kg
15.6"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Front zippered pocket
Weather resistant
Carrying Strap
Ventilated Back
Ventilated Back Type
Mesh material
Limited warranty: - lifetime
Device Type: Laptop
Type: Backpack
Brand: Targus
