Targus Folio Wrap + Stand for Microsoft Surface Pro 4 - Grey
Quicklinx: CYKMWS00 Mfr#: THZ618GL
The Surface Pro 4 Protective Folio Case is a light, form-fit case which wraps securely around your Microsoft Surface Pro 4. The two-piece design ensures your device is always protected: A shock-absorbing perfect-fit tray clicks securely onto the device and folds into a stand, while the removable folio cover wraps around and secures magnetically to provide screen protection on the go. This cover also has soft corners for added protection. This case can be used with or without your Type Cover keyboard.
Two-Piece DesignWith soft corners ensures all-round, form-fit protection for your Microsoft Surface Pro 4.Removable Wrap-Around Folio Cover Secures magnetically for screen protection on the go, while your device sits in a shock-absorbing protective tray for front, rear and side protection
Removable Wrap-Around Folio CoverSecures magnetically for screen protection on the go, while your device sits in a shock-absorbing protective tray for front, rear and side protection.
Both The Folio Cover And Protective Tray Can Be Folded Back To use your Surface with the stand for comfortable viewing and convenient typing angles.
Works with or without Type Cover KeyboardFolio cover protects both device and keyboard when on the go.
  • Adjustable viewing and typing
    This case lets you position your Surface Pro 4 for optimal viewing angles, with or without using the kickstand. A molded tray with a hinge works with the Surface kickstand feature, maximizing your Surface Pro 4 experience.
  • Full functionality
    The molded tray is precision-cut for easy access to the camera, ports, buttons and controls. The tray conforms to the Surface Pro 4 and has an integrated hinge to allow use of the kickstand function with the tray in place.
Targus Foliowrap - flip cover for tablet
Flip cover for tablet
31.2 cm x 2.56 cm x 22.5 cm
498 g
Material
Thermoplastic polyurethane (TPU)
Grey, black
1-year warranty
31.2 cm
2.56 cm
22.5 cm
498 g
Material
Grey, black
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Shockproof, drop-proof
Cover Type
Flip cover
Open Type
Side
22.5 cm x 2.6 cm x 31.2 cm / 0.5 kg
Stylus pen holder
Cover Features
Stand function
1 year
