Targus Ergo M-Pro Notebook Stand
Quicklinx: 6Z7CWS00 Mfr#: AWE04EU
£62.24 ex VAT
£74.68 inc VAT
The Ergo M-Pro Notebook Stand is a compact, thin and lightweight ergonomic notebook stand. It has multiple tilt positions to hold the notebook in a vertical position and allows the notebook LCD to be used as the display while being positioned higher relative to eye level. The Ergo M-Pro Notebook Stand also incorporates a document holder which is positioned directly in front of the notebook user. When not in use, the Ergo M-Pro Notebook Stand will collapse into a relatively flat product, which can then be packed away easily for extended stays out of the office or indeed to take with you on the road. Compatible with all PC and Mac notebooks up to 17". Must be used in conjunction with a separate keyboard.Awarded Ergonomic Excellence by the Furniture Industry Research Association.
  • Enhanced ergonomics
    The Targus Ergo M-Pro notebook stand is designed with tilt adjustment and a built-in document holder, promoting a more comfortable and ergonomic workspace. This thoughtful design helps in reducing neck strain and improving posture during long hours of work.
  • Robust compatibility
    Accommodating notebooks up to 17 inches or 43.2 cm, this stand is versatile and suitable for a wide range of notebook sizes, ensuring your device fits securely for an optimized viewing experience.
Targus Ergo M-Pro - notebook stand
Notebook stand
Silver, dark grey
Product Material
Plastic
23 cm x 35.5 cm x 2 cm
490 g
Notebook Compatibility
17"
Tilt adjustment, built-in document holder
Notebook stand
Product Material
Plastic
23 cm
35.5 cm
2 cm
490 g
17"
Silver, dark grey
Limited warranty: - 2 years
