Targus Docking station - USB-C 3.2 Gen 1 / Thunderbolt 3 –
Quicklinx: GPS2WS00 Mfr#: DOCK419EUZ
25 In Stock
£42.09 ex VAT
£50.50 inc VAT
Turn your laptop into a workstation with the compact USB-C DP Alt Mode Single Video 4K HDMI/VGA Docking Station with 100W PD Pass-Thru.
Connect your USB-C-enabled devices to a single HDMI or VGA display, while also connecting to a Gigabit Ethernet network, and plugging in your key peripherals - like mice, keyboards, flash drives or hard drives - into the USB-A and USB-C ports. You can even keep your laptop charged and powered by connecting your laptop's USB-C power adapter to the USB-C port on the dock.
It supports up to 100W (20V/5A) charging max. This dock also provides transfer speeds up to 5Gbps per port. Compact and lightweight, it's easy to take it along with you anywhere you go.
  • HD or 4K UHD Display
    Whether you want to run a presentation on a larger display or use an external display, Targus’ single video 4K docking station supports either one VGA display up to 1920x1200@60Hz or one HDMI display up to 4K@30Hz.
  • Connectivity Made Simple
    Enhance your productivity and connect to more with 2 USB-A 3.2 Gen 1 ports (1 fast-charging) and 1 USB-C 3.2 Gen 1 port.
  • Charge and Power Host Device
    The dock with 100W Power Delivery pass-through allows you to power and charge your USB-C laptop or host simply by connecting the laptop’s power adapter into the USB-C port — great for those laptops with only one USB-C port.
  • Perfectly Portable
    Slim and light, Targus’ 4K docking station is perfect for the home, office or anywhere in between. It's great for mobile workers or those in hoteling or hot-desking environments.
  • Plug and Play Simplicity
    Targus’ 4K docking station was made for ease of use. With no need for additional software, this adapter easily attaches to your USB-C or Thunderbolt™ 3 host device (e.g. laptop) to help you connect to a wired network, more peripherals, and transfer data.
Targus - docking station - USB-C 3.2 Gen 1 / Thunderbolt 3 - VGA, HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
VGA, HDMI
9.5 cm x 5.2 cm x 1.4 cm
80 g
Grey
Gigabit Ethernet
Docking station
9.5 cm
5.2 cm
1.4 cm
80 g
Enclosure Colour
Grey
Video
Max Resolution Details
4K - 30 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
Gigabit Ethernet
Power Delivery 3.0, USB 3.2 Gen 1, Battery Charging 1.2
1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB 3.2 Gen 1 with Fast Charging - 9 pin USB Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 with Power Delivery (100 W) - 24 pin USB-C , 1 x network - 1000Base-T - RJ-45
1 x USB-C cable - integrated
4K Ultra HD, DisplayPort Alt Mode, 100W power delivery
Plug and Play
Apple MacOS, Microsoft Windows, Google Chrome OS
Brand: Targus
