Targus DEFCON SCL Serialised Cable Lock (25 pack)
Quicklinx: BBS4WS00 Mfr#: PA410S
The Targus DEFCON® SCL (Serialised Cable Lock) is a serialised lock with a pre-set combination. This Targus laptop security product finally provides a computer security solution for complete asset protection. The Targus DEFCON Serialised Cable Lock (SCL) is 2 meters of cut-resistant, galvanized steel cable that loops around any secure object and easily attaches to your laptop computer's lock slot. Our DEFCON SCL features a pre-set combination lock in which your IT Manager has access to all combinations via a secure password protected web site. The DEFCON SCL is the first laptop computer security product to offer the benefits and convenience of a keyless security solution.
  • Enhanced security
    The Targus DEFCON security cable lock is designed with a cut-resistant galvanized steel cable, ensuring your notebook remains secure in public spaces. Its robust material deters theft and provides peace of mind.
  • Convenient protection
    Featuring a serialized combination lock, this security solution offers a hassle-free way to protect your device. The combination mechanism eliminates the need for keys, while the serialization ensures easy recovery of the combination if forgotten.
  • Versatile compatibility
    Equipped with a T-Lock mechanism, the Targus DEFCON security cable lock is intended for notebooks, offering a universal fit for a wide range of devices. This versatility ensures your essential tech is safeguarded, regardless of the brand or model.
Targus DEFCON - Master Pack - security cable lock
Security cable lock
Packaged Quantity
25 (specifications are for single item)
Grey
Product Material
Galvanised steel
Length
2 m
200 g
Cut-resistant, serialised combination lock
Packaged Quantity
Security cable lock
Product Material
Galvanised steel
Length
2 m
Diameter
0.4 cm
200 g
Grey
Security Cable Lock
Intended For
Notebook
Lock Type
T-Lock
Lock Method
Combination
Limited warranty: - 2 years
