Targus Defcon CL Security Cable
Customer rating: 5.0* (Write a review)
Quicklinx: KBVWS00 Mfr#: PA410E
Hurry, only 3 left in stock!
£26.71 ex VAT
£32.05 inc VAT
Everyday nearly 1,000 laptop computers are stolen - protect your laptop computer and its valuable data with this affordable laptop security product - the DEFCON® CL. The DEFCON® Cable Lock (CL) is 2.1 metres of galvanized steel cable that loops around any secure object and easily attaches to your laptop computer's lock slot. Our DEFCON® CL features a user-settable combination lock with up to 10,000 possible settings. The DEFCON® CL is the first laptop computer security product to offer the benefits and convenience of a keyless security solution.
Targus DEFCON - security cable lock
Security cable lock
Grey
Product Material
Galvanised steel
Length
2 m
200 g
Cut-resistant, serialised combination lock
Security cable lock
Product Material
Galvanised steel
Length
2 m
Diameter
0.4 cm
200 g
Grey
Security Cable Lock
Intended For
Notebook
Lock Type
T-Lock
Lock Method
Combination
Limited warranty: - 2 years
Customer reviews
Write a review for the Targus Defcon CL Security Cable here!
Works well
Reviewed by Mark Elder. Review Posted 05/01/2007
Combination lock on the "laptop" end of the cable is easy to set up with your own code.
Laptop end turns so you can see the code from any angle that you laptop's security slot might require.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Security Cable
Brand: Targus
