Targus Cord-Storing Mouse - Black/Grey
Quicklinx: BBRPWS00 Mfr#: AMU76EU
The Targus Cord-Storing Optical Mouse features a patented cord storing design that retracts the 61cm long USB cord completely inside of the mouse for easy and tangle-free travel. The cord can also be adjusted to any langth and the ergonomic, ambidextrous mouse design helps prevent palm strain. Utilizing the latest 1,000 DPI optical technology for precise tracking, the Cord-Storing Optical Mouse helps keep the workspace neat without the clutter ao excess cables.
  • Optical sensor technology
    1,000 dpi optical sensor provides improved accuracy and precise mouse movements.
  • Dual-purpose design
    This mouse is large enough for comfortable desktop use, yet small enough for the mobile user.
  • Ergonomic
    Ergonomic shape provides support to help prevent palm strain; designed for left and right handed users.
  • Retractable cord
    Retractable USB cable provides cable management for easy travel.
Targus Cord-Storing - mouse - USB - black, grey
Mouse
Wired - USB
Black, grey
Orientation
Right and left-handed
5.5 cm x 10 cm x 3.5 cm
70 g
Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Retractable cable, scrolling wheel
Cable Length
75 cm
Microsoft Windows, Apple MacOS
Mouse
Orientation
5.5 cm
10 cm
3.5 cm
70 g
Black, grey
Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
75 cm
1 x USB - 4 pin USB Type A
