Targus Compact Wireless Laser Mouse
Quicklinx: BBRYWS00 Mfr#: AMW55EU
The Targus Wireless Compact Laser Mouse is the perfect solution for mobile users who need to save space when using an external mouse. The sleek design provides added style, whilst the integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The high definition laser sensor provides enhanced precision and accuracy in your clutter free environment. The mouse also features a low power indication light and micro USB receiver which is small enough to leave permanently plugged into your computer alternatively using the built-in Stow-N-GoTM technology the USB receiver can be easily stored away inside the mouse itself, for safe travelling.
  • Optical Sensor technology
    1000 DPI high-precision laser sensor technology accurately responds to mouse movements.
  • Easy storage
    Stow-N-go design helps portability by keeping the USB port stored inside the body of the mouse.
  • Ergonomically designed
    Provides long lasting comfort due to its sleek, ergonomically form.
Targus Wireless Compact Laser - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
4.5 cm x 8.3 cm x 3.3 cm
39 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Movement Resolution
1000 dpi
Scrolling wheel
2 x AAA type
Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
Mouse
Wireless Receiver
Orientation
4.5 cm
8.3 cm
3.3 cm
39 g
Input Device
Wireless
2.4 GHz
Laser
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
RoHS
AAA type
Installed Qty
2
Run Time (Up To)
5 months
Additional Requirements
USB port
