The Universal Monitor Stand allows you to regain valuable desktop space by elevating your external monitor to a more ergonomically correct height and housing your notebook computer and docking station in the same space that your monitor used to occupy. To access your notebook you simply pulling out the convenient sliding tray. The open architectural design provides quick access to all of your notebook computer’s PC Card slots, bays, diskette and DVD/CD-ROM drives. The stand will support an external monitor weighing up to 40 Kg. It also includes a riser that will allow the customer to raise the monitor stand height (from 85 mm to 136 mm). This stand is perfect for the home or the office.
Adjustable comfort
The Targus Universal monitor stand features an adjustable height setting, allowing users to find their optimal viewing angle for enhanced ergonomic comfort during long work sessions. -
Efficient organization
Equipped with a sliding tray, this monitor stand offers a neat solution for organizing your desk space, ensuring your keyboard and other accessories are tucked away when not in use.
- Targus Universal monitor stand
- Product Type
- Monitor stand
- Placing / Mounting
- Desktop
- Black
- 44 cm x 35.3 cm x 13.1 cm
- 2 kg
- 2-year warranty
- Product Type
- Monitor stand
- Desktop
- Max Load Weight
- 40 kg
- 44 cm - 35.3 cm - 13.1 cm
- 2 kg
- Black
- Adjustable height, sliding tray
- Limited warranty - 2 years
