Targus Click-in Rotating Case fits the 10.5-inch iPad Pro with a shock-absorbing form-fit tray providing access to iPad ports and camera. Sound scoops built into the case around your device speakers enhance and direct sound towards you. The front cover has a soft interior to protect the device screen and transforms into a stand offering hands free portrait & landscape viewing plus a comfortable typing position.
                Enhanced durabilityDesigned to withstand the rigors of daily use, this protective cover offers shockproof and water-resistant protection, ensuring your tablet remains safe from drops up to 1.2 m and exposure to water.
                Versatile functionalityFeaturing a rotating flip cover with stand function, this case allows for seamless transition between landscape and portrait views, providing optimal viewing angles for both productivity and entertainment.
                Superior comfort and protectionThe microfiber lining of the cover not only adds an extra layer of protection against scratches but also ensures your tablet's screen stays clean and clear, enhancing the overall user experience.
- Targus Click-In Rotating - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10.5"
- 18 cm x 1.7 cm x 25.7 cm
- 380 g
- Black
- Limited lifetime warranty
- Designed For
- Apple 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
- 18 cm
- 1.7 cm
- 25.7 cm
- 380 g
- Lining Material
- Microfibre
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10.5"
- Protection
- Shockproof, water-resistant
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Elastic band closure
- Cover Features
- Stand function, rotating
- Max Height of Drop Protection
- 1.2 m
- Lifetime
- Designed For
- Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
