Targus Classic+ 13-14.1" Topload case - Black/Red
Quicklinx: 8WD8WS00 Mfr#: cn514eu
The new Classic+ top load laptop case is designed protect 14.1” widescreen laptops. The new inner sleeve with security strap safeguards the surface and gives additional overall protection to your laptop. The re-enforced handles are wrapped in a soft neoprene with smart faux leather trim to provide comfort and strength. An easy to use functional front zipped organizer will neatly store your mobile phones, pens, business cards, and cables / earphones etc. It also features an additional section to store and protect your tablet / iPad. The case comes with an adjustable comfortable strap when carrying the case on your shoulder.
Targus Classic+ 13 - 14.1" / 33 - 35.8cm Toploading Case - notebook carrying case
Notebook carrying case
Product Material
Polyester
36.8 cm x 10.8 cm x 28.9 cm
0.63 kg
Notebook Compatibility
14.1"
Zippered, touch fastener, adjustable shoulder strap, external zip pocket
Carrying Strap
Shoulder carrying strap, soft padded handle
Europe
Product Material
Polyester
36.8 cm
10.8 cm
28.9 cm
0.63 kg
14.1"
Notebook Compatibility Dimensions
34 cm x 3.8 cm x 24 cm
Additional Compartments
Mobile phone, headphones, cable, pens, business cards, organizer, tablet
Carrying Strap
Europe
Limited warranty: - lifetime
