The new Classic+ laptop case is designed protect 12.1” widescreen laptops. The new inner sleeve with security strap safeguards the surface and gives additional overall protection to your laptop. The re-enforced handle is wrapped in a soft neoprene to provide comfort and strength. An easy to use functional front zipped organizer will neatly store your mobile phones, pens, business cards, and cables / earphones etc. The case comes with an adjustable comfortable strap when carrying the case on your shoulder.
- Targus Classic+ 10 - 12.1" / 25.4 - 30.7cm Clamshell Case - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester
- 34.29 cm x 8.26 cm x 27.31 cm
- 0.57 kg
- Notebook Compatibility
- 12.1"
- Zippered, touch fastener, adjustable shoulder strap, external zip pocket
- Carrying Strap
- Shoulder carrying strap, soft padded handle
- Localisation
- Europe
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 34.29 cm
- 8.26 cm
- 27.31 cm
- 0.57 kg
- 12.1"
- Notebook Compatibility Dimensions
- 29 cm x 3.5 cm x 24 cm
- Additional Compartments
- Mobile phone, headphones, cable, pens, business cards, organizer, tablet
- Carrying Strap
- Black
- Localisation
- Europe
- Limited warranty: - lifetime
