A Compact Cooling Platform for your Laptop. Turn your laptop into a workstation with the Targus Chill Mat+ with 4-port Hub. Dual fans keep your laptop cool, a 4-port hub allows you to connect all your peripherals, plus the adjustable height allows you to use it as a laptop stand. Use it flat, or at the highest setting (4") with an external keyboard for better ergonomics.
- Targus Chill Mat - notebook stand
- Product Type
- Notebook stand
- Built-in Devices
- 4-port USB 2.0 hub
- Grey, black
- Fans Qty
- Dual
- Rotation Speed
- 2500 rpm
- 35.5 cm x 26 cm x 2.5 cm
- 900 g
- Adjustable height, 4 step adjustable height
- Localisation
- Europe
- 2-year warranty
- Product Type
- Notebook stand
- Built-in Devices
- 35.5 cm
- 26 cm
- 2.5 cm
- 900 g
- Grey, black
- Localisation
- Europe
Heatsink & Fan
- Fans Qty
- 2
- Rotation Speed
- 2500 rpm
- Limited warranty: - 2 years
