The Targus 90W AC mains notebook power adapter offers a versatile replacement, or secondary power supply for your notebook at home or in the office, ensuring you remain switched on and productive. The inclusion of a number of power tips provides compatibility with many of today's major 19 Volt notebook brands requiring up to 90W of continuous power . Reliable, safe and easy to use the, this unit will not let you down. Whether it’s a replacement or additional power supply you require, let Targus make your mobile life easier. Note: This product does not support the Samsung Q210.
- Targus - power adapter - 90 Watt
- Power adapter - external
- 440 g
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Included Accessories
- Notebook power tips
- Black
- 13.2 cm x 5.7 cm x 3 cm
- 2-year warranty
- Black
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Cables Included
- Power cable kit
- FCC Class B certified, UL, TUV, C-Tick
- Limited warranty - 2 years
- 13.2 cm
- 5.7 cm
- 3 cm
- 440 g
