Targus 4-Port USB Hub - Black
Quicklinx: BBSWWS00 Mfr#: ACH114EU
Type: USB Hub
Ports: 4
£6.64 ex VAT
£7.96 inc VAT
The Targus USB 2.0 4-Port hub allows connection of up to 4 USB Devices whilst on the move. Plug and Play functionality ensures this hub is simple and easy to use whilst the device draws power from the notebook ensuring a bulky AC adapter is not required on your travels. High speed USB 2.0 connectivity ensures fast and reliable data transfer of up to 480Mbps to a variety of devices such as mice, flash drives, and MP3 players, keyboards, USB adapters and Digital Cameras. The attached USB cable prevents loss or damage to the cable while conveniently clipping to the base of the hub for easy transportation. This lightweight travel hub is ideal for use at home or on the road and is compatible with both PC and Mac.
Targus 4-Port USB Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
8.4 cm x 3.1 cm x 1.3 cm
29.5 g
Apple MacOS X 10.0 or later, Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7
Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
4 x USB Type A , 1 x USB Type A
Europe
Additional Requirements
USB 2.0 port
8.4 cm
3.1 cm
1.3 cm
29.5 g
BBSW C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
BBSW C2G 5m USB 2.0 A/B Cable - Black In Stock £5.10
BBSW C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.97
Type: USB Hub
Ports: 4
Brand: Targus
Price Range Ex VAT: 0 - 50
