Targus 19" Privacy Screen
CLEARANCE!
Clearance
Price Drop
Quicklinx: 506FWS00 Mfr#: ASF190EU
Keep your business your business with a Targus Privacy Screen.  Our Privacy Screens can be used on the majority of devices and only allow normal viewing of on-screen data from directly in front of it. They also act as a screen protector. The privacy screen is double-sided to ensure clarity and prevent eyestrain wherever you are working, whether there is high glare or not. An Anti-microbial coating inhibits the growth of bacteria making it ideal for use with touch screens. Working life has become more mobile and increasingly we are working in busy public spaces such as coffee shops, restaurants and airports. Using a Targus Privacy Screen means you can work productively and comfortably with confidential business information wherever you are, in the knowledge that your on-screen data is protected from prying eyes.
  • Enhanced privacy
    The Targus Privacy Screen is designed to protect sensitive information from prying eyes. With a +/- 30° visible angle, it ensures that your data is visible only to you, making it an essential tool for maintaining privacy in public spaces or open office environments.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen offers the flexibility to choose your preferred viewing experience. Whether you're working under bright office lights or in a cozy cafe, you can switch between a glossy or matte finish to reduce glare and reflections.
  • Eye comfort
    Equipped with an anti-glare, anti-reflective, and blue light filter, the Targus Privacy Screen not only protects your privacy but also minimizes eye strain. It's an ideal choice for users who spend long hours in front of the screen, providing a more comfortable viewing experience.
  • Touchscreen compatibility
    This display privacy filter doesn't compromise on functionality for touchscreen devices. It's fully compatible with touchscreens, ensuring that you can continue to enjoy the convenience of touch navigation without sacrificing privacy or screen clarity.
Targus Privacy Screen - display privacy filter - 19"
Display privacy filter
Installation Type
Removable
Display Screen Size Compatibility
19"
37.5 cm 30 cm
80 g
Dell E190S, E1913S, P190S; Professional P190S, P1913S
19"
37.5 cm 30 cm
80 g
Display Filter
Installation Type
Removable
Aspect Ratio
4:3
Surface Finish
Glossy/matte
Touch screen compatible, blue light filter, anti-glare, anti-reflective, +/- 30° visible angle
Dell E190S, E1913S, P190S , Dell Professional P190S, P1913S
