This beautiful collection of laptop cases brings a contemporary slant on classic design. Each case has been carefully crafted with a stylish approach to practicality. Constructed from quality materials, each case features a protective padded laptop section so you can be sure that your laptop is safe Carrying is made comfortable with a cushioned shoulder pad. The length of the shoulder strap is adjustable and the strap can be removed completely if desired. Keeping belongings organised is easy with a selection of sized pockets designed for convenience, easily accessible in front zip down section.
Protection
Padded 13.3" laptop section. -
Comfort
Adjustable shoulder strap. Compact and lightweight. -
Size
Fits laptops up to 13.3".
- Targus Classic Clamshell - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester
- 37 cm x 7 cm x 29 cm
- 500 g
- Notebook Compatibility
- 13.4"
- Notebook Supported Sizes
- 12" - 13.4" / 30.5 cm - 34 cm
- Padded notebook compartment
- Carrying Strap
- Top carrying handles, removable/adjustable padded shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 37 cm
- 7 cm
- 29 cm
- 500 g
- 13.4"
- Notebook Compatibility Dimensions
- 32.5 cm x 22.7 cm x 3.9 cm
- Additional Compartments
- Front zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - lifetime
