The Tandberg RDX QuikStor cartridge delivers a rugged design that's shock-proof for maximum data protection and secure handling. Reliability is ensured with a load mechanism guaranteed for more than 10 K load/unload and a soft eject feature that protects data from unwanted eject errors. RDX QuikStor is compatible with all major backup applications so it fits seamlessly into your established backup routines. Backward/forward compatibility allows users to scale to higher capacities, meaning that tomorrow's higher capacity RDX cartridges will operate in today's RDX systems. Tandberg Data's RDX QuikStor meets the reliability, performance and business requirements for all backup and data archive applications-from professional workstations through to the low-end enterprise.
Easy
RDX QuikStor combines the portability and reliability of tape-based backup with the speed and simplicity of a hard disk drive. Compact internal or external RDX drives accept pocket-sized RDX media. Your computer will recognize each cartridge and provide instant access and easy drag-and-drop control. -
Fast
Write and read access is near-instant allowing users to work directly with the data on the media like one would with any other hard disk drive. With RDX capacities ranging from 500GB, 1TB, 2TB, 3TB, 4TB to 5TB, users have enough capacity to support a wide range of storage requirements, ensuring their data is fully protected. -
Rugged
RDX drives are tough, and media is shockproof and rugged enough to last more than 10 years. Knocks and drops don't mean lost data. Plus valuable data can be further protected through Tandberg Data's RCE encryption software, ensuring complete peace of mind. -
Portable
The RDX media is small and durable, so slip easily into a pocket for easy transport. They can be carried to another site for use by another computer or moved off-site for archiving. -
Mobile
The external RDX USB3+ drive only needs a USB3.0 connection to work. It is as easy to use as an external USB disk drive but much more robust and reliable. This enables RDX for outdoor usage like scientific data collection, in the media and entertainment environment, mobile workforce or just for easy data distribution across locations.
- Overland Tandberg RDX QuikStor - RDX HDD cartridge x 1 - 2 TB - storage media
- Storage media - RDX HDD cartridge
- Media Included Qty
- 1
- Native Capacity
- 2 TB
- Microsoft Certification
- Compatible with Windows 7
- Designed For
- Tandberg Data RDX QuikStation 4, RDX QuikStation 8, RDX QuikStor
- RDX HDD cartridge
- 1
Media
- Native Capacity
- 2 TB
- Designed For
