The Smart Thermostat is the central element in your living space. Here you can see the current temperature and set or alter the setpoint temperature. It does not matter which type of heating you have or from which manufacturer, the tado° Smart Thermostat works with almost all systems: combi, system and heat-only boilers, conventional and condensing boilers, zoned systems, hydronic and electric underfloor systems and heat pumps.
- tado° Smart Thermostat - thermostat - matt white
- Product Type
- Thermostat
- Functions
- Control heating systems
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Siri, Alexa - indirect
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- Supported Host Device OS
- iOS, Android, Windows Phone
- Display
- LCD
- Matt white
- 10.4 cm x 1.9 cm x 10.4 cm
- Product Type
- Thermostat
- Functions
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- Android 2.3 or later, Windows Phone OS 8.1, iOS 7.1 or later
- Display
- LCD
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Communications Type
- Product-to-product
- Communications Technology
- 6LoWPAN
- Siri, Alexa
- Voice Controlled
- Indirect
Thermostat
- Modes
- Auto, manual, programme
- Backlit display, matrix display
- Form Factor
- AAA type
- Required Qty
- 3
- Included Accessories
- 3 AAA batteries, screws, screwdriver
- Matt white
- Encryption Algorithm
- 256-bit SSL, TLS 1.2
- RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2014/35/EU, R&TTE Directive 1999/5/EC
- 10.4 cm
- 1.9 cm
- 10.4 cm
- 132 g
