tado Additional Smart Thermostat
Quicklinx: D3Q0WS00 Mfr#: ST01-TC-ML-03
Type: Thermostat
Compatible With: Alexa, Google Assistant, IFTTT
£90.84 ex VAT
£109.00 inc VAT
The tado° Additional Smart Thermostat uses the intelligence of the web to offer you a high level of comfort while ensuring that no energy goes to waste.
This is an additional product of the tado° Starter Kits. You can add additional Smart Thermostats to your setup to control multiple rooms or zones independently from one another.
How tado° controls your heating
The Smart Thermostat and the Smart Radiator Thermostats connect to the internet and control your heating system or radiators.
Location-based control - The tado° Smart Thermostat automatically turns down your heating when the last person leaves home and begins to warm up again when it detects the first person returning.
The tado° app - With the tado° app on the residents’ smartphones, tado° detects how far they are away from home and sets the temperature accordingly. You can also manually control your heating.
Integrations
The new product suite offers several integration possibilities, such as Apple HomeKit, Google Home, Amazon Echo, and IFTTT.
Make tado° part of your connected home and create scenes with Apple HomeKit. Use Siri, Google Assistant or Amazon Echo to voice control your heating and create Applets with IFTTT to connect with other applications and smart devices.
Thermostat
The Smart Thermostat can be automatically controlled via the location of your smartphone as well as manually, by schedule or on the device itself.
LED matrix display - shows current temperature and settings
Touch arrows - to manually change the temperature and other settings
Button - to activate the display, scroll through the settings and make changes
  • Geofencing
    tado-¦ heating control carefully reduces the temperature of your home when the last person leaves - always keeping in mind to efficiently warm the home before you return.
  • Weather forecast
    For better heating control tado-¦ takes the weather forecast into account to save energy and prevent your home from getting too warm. This is especially helpful if you have a well-insulated house or underfloor heating.
  • Building characteristics
    Every house and heating system is different, so tado-¦ learns over time how to heat yours as efficiently as possible.
tado° Smart Thermostat - Add-on - thermostat
Thermostat
Functions
Control heating systems
Power Source
Wireless
Frequency Band
868 MHz
Supported Host Device OS
iOS, Android, Windows Phone
Thermostat
LED
Matt white
10.4 cm x 1.9 cm x 10.4 cm
Thermostat
Functions
Power Source
Wireless
Frequency Band
868 MHz
Android 2.3 or later, Windows Phone OS 8.1, iOS 7.1 or later
Touch control
Thermostat
Display
LED
Matrix display
Aerial
Internal
3 AAA batteries, screws, screwdriver
Product Material
Polycarbonate, ABS plastic
Matt white
Encryption Algorithm
AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
Battery Required
3 x AAA type
ISO 9001, ISO 14001, RoHS, OHSAS 18001
10.4 cm
1.9 cm
10.4 cm
132 g
Type: Thermostat
Compatible With: IFTTT
Brand: tado
Price Range Ex VAT: 50 - 100
