Synology Synology RS812+ 16TB 1u Rack NAS
Quicklinx: 83KZWS00 Mfr#: RS812+/16TB
Synology RackStation RS812+ offers a high-performance, scalable, and full-featured rack mounted network attached storage solution that meets the needs of small and medium-sized businesses that require an efficient way to centralize data protection, simplify data management, and rapidly scale up storage capacity with minimal time spent on setup and management.
Synology RS812+ brings you the high performance that your data-intensive applications demand for a storage system, and offer the ability to scale the storage capacity. Businesses need a strong foundation to face mission-critical tasks. Synology RS812+ delivers high data availability to ensure access when it's needed. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure. In the event of a hardware failure, the RS812+ is made for easy maintenance without removing from the rack. The motherboard inside is made for easy access and replacement. No additional system re-configuring is needed, and RS812+ can be brought back on the line with your existing data.
Windows ADS integration allows the Synology RS812+ to quickly and easily ft in an existing business network environment with no need to recreate users' accounts on the Synology RS812+. The user home feature minimizes the administrator's effort in creating a private shared folder for a large amount of users.
  • Experience high performance data throughput
  • High reliability for critical business applications
  • Fit to business environment
  • iSCSI and virtualization ready
    With the iSCSI support in DiskStation Manager (DSM), the Synology RS812+ provides a seamless storage solution for virtualization servers, such as VMware, Hyper-V, and Citrix. It is the ideal alternative to SAN solution for businesses. Affordable and cost-effective, iSCSI allows SMB users to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks.
  • Energy efficient design
    Synology DiskStations are designed and developed with energy efficiency in mind. Compared with the average PC counterparts, the Synology RS812+ consumes relatively low amount of power at 46.2 watts only in operation. The support of wake on LAN/WAN and scheduled power on and of can further reduce power consumption and operation cost. HDD hibernation or deep sleep mode can be configured to take effect automatically when the system has been inactive for a specified period of time. This not only saves energy but also extends the lifespan of the hard disks.
Synology RackStation RS812+ - NAS server - 16 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
16 TB
4 (installed) / 4 (max)
45.7 cm x 43.1 cm x 4.4 cm
7.1 kg ()
2.13 GHz
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 4 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
TAA Compliant
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
16 TB
45.7 cm
43.1 cm
4.4 cm
7.1 kg ()
Built-in Devices
Led panel, print server
Processor / Memory
Processors Installed
2.13 GHz
RAM
1 GB DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap - 3.5"
4 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, AppleTalk, iSCSI, LPR/LPD, FTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, Advanced Data Streaming (ADS), SSH support, iTunes server, Samba support, FTP server, SMS alert, e-mail server, UPnP Media Server
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 3Gb/s
FCC Class A certified, RoHS
TAA Compliant
Internal power supply
Software Included
Synology Assistant, Synology Data Replicator
TAA Compliant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
25.1 dBA
