Synology SNV3400 400GB M.2 NVMe SSD
Quicklinx: FW6DWS00 Mfr#: SNV3400-400G
The Synology SNV3400 NVMe SSD is designed to handle tough caching workloads in a 24/7 multi-user environment. Its durable I/O performance boosts system responsiveness and speeds up handling of frequent access data, providing a streamlined storage experience while minimizing service disruptions to your Synology NAS.
Designed for use in Synology systems only, warranty claims will be rejected when used in non-Synology devices
  • Consistently fast caching for 24/7 environments
    Built for system cache, the Synology SNV3400 pushes up random I/O performance and reduces latency in demanding 24/7 environments. It offers durable caching and it is suitable for multimedia post-production and database applications.
  • Data integrity safeguards
    The Synology SNV3400 integrates end-to-end data protection to safeguard data integrity over the entire transfer path.
  • Timely notifications
    Plan further ahead for uninterrupted system performance and longevity with timely notifications.
Synology SNV3400-400G - SSD - 400 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
400 GB
M.2 2280
PCIe 3.0 x4 (NVMe)
NVM Express (NVMe), End-to-end data protection
22 mm x 80 mm x 3.5 mm
5-year warranty
Disk Station DS1618+, DS1819+, DS2419+; RackStation RS2818RP+, RS820+, RS820RP+
400 GB
M.2 2280
PCIe 3.0 x4 (NVMe)
22 mm
80 mm
3.5 mm
Performance
Drive Writes Per Day (DWPD)
0.68
SSD Endurance
500 TB
Internal Data Rate
3100 MBps (read) / 550 MBps (write)
Maximum 4KB Random Write
40000 IOPS
Maximum 4KB Random Read
205000 IOPS
Reliability
MTBF
1,800,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
3.2 watt (read) , 3.2 watt (write) , 2 watt (idle)
FCC, BSMI, VCCI, RCM, KC, RoHS
Limited warranty - 5 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Synology Disk Station DS1618+, DS1819+, DS2419+ , Synology RackStation RS2818RP+, RS820+, RS820RP+
