Synology SA3400 12 Bay Rack-Mountable
Quicklinx: FB2DWS00 Mfr#: SA3400
Type: Rackmount Kit
Controller Type: [N/A]
  • Xeon
Hurry, only 1 left in stock!
£3,225.80 ex VAT
£3,870.96 inc VAT
Synology 12 Bay NAS Rack Enclosure (SA3400)
The Synology SA3400 is a 12-bay rackmount NAS designed for large and extensive scaling of data storage. Its comprehensive data protection technologies, including High Availability, hybrid cloud backup, and server or virtual machine backup approaches, make it a reliable server for massive storage deployment.
Synology NAS Rack Enslosure (SA3400) Key Features
A highly scalable rackmount NAS to aptly accommodate large businesses' needs for scalability, suitable for video post-production and massive surveillance deployment
TCO-optimized storage companion, offering various and flexible support for both SAS and SATA drives
Scale up to 180/96 drives when connected with 7 RX2417sas/RX1217sas
Built-in dual 10GbE and quad 1GbE ports with failover and Link Aggregation support
Elastic expandability with dual PCIe 3.0 x8 slots for installing additional 10/25GbE network interface cards
Effortless data protection for your physical server, virtual machines, and cloud services through Synology Active Backup Suite
Advanced iSCSI storage supports various virtualization deployment, including VMware vSphere®, Windows Hyper-V®, Citrix XenServer®, and OpenStack Cinder®
Backed by Synology's 5-year limited warranty
  • Small-to-hyperscale flexibility
    Scalable up to 180/96 drives delivering more than 1.5 petabytes raw capacity, SA3400 can easily fulfill extensive storage needs, including video post-production and massive surveillance deployment.
  • Supercharge network performance effortlessly
    Built-in dual 10GbE Ethernet ports and dual PCIe 3.0 slots provide high-speed network transmission with additional network interface cards' expansion.
  • Btrfs: next-generation storage efficiency
    Btrfs file system introduces the most advanced storage technologies to meet the management needs of modern large scale businesses.
  • Fully certified storage virtualization solutions
    Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface.
Synology SA3400 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
48.2 cm x 72.4 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1541 2.1 GHz (8-core)
Storage Controller
RAID RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
100
RAM
16 GB
Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
16 GB (installed) / 128 GB (supported) - DDR4
Registered, ECC
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, SMB, NFS, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, wake on LAN (WOL), antivirus analysis, High Availability, download client, anti-malware protection, Access Control List (ACL) support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, Link Aggregation, failover protection, DLNA support, OpenStack compatible, B-tree file system (Btrfs), file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
Encryption Algorithm
AES-NI
Security DVR
100
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
Built-in 4 cooling fans
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
137.17 Watt
Power Provided
500 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
49.8 dBA
Hard Drives
FB2D Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £429.27
FB2D Synology 8TB HAS5300 3.5" SAS Hard Drive In Stock £242.18
FB2D Synology 12TB HAS5300 3.5" SAS Hard Drive In Stock £376.99
Type: Rackmount Kit
Brand: Synology
Price Range Ex VAT: £1500+
