Synology RXD1215sas/48TB-RED PRO 12 Bay
Quicklinx: BKBPWS00 Mfr#: RXD1215SAS/48TB-RED PRO
Featuring a high-availability design, next-generation snapshot technology, and massive scalability up to 180 drives, RXD1215sas delivers the secure, reliable, and superior performance storage solution for enterprises seeking business continuity and point-in-time data recovery.
  • Massive scalability up to 180 drives
    Up to fifteen RXD1215sas can be connected to the dual RC18015xs+ computing nodes, accommodating massive scalability up to 180 drives and maximum raw storage beyond 1PB. The shared storage architecture eliminates the need for data replication over the network, in addition to drastically reducing deployment costs.
  • Hardware redundancy enhances system uptime
    In addition to the active/passive architecture, RXD1215sas is equipped with redundant hardware components, such as power supply units, SAS modules, SAS connection cables, system fans, LAN ports, and even the Heartbeat connection. In the event of component failure, the system continues operating normally while replacement parts are obtained and installed.
  • High-availability cluster design
    By combining two computing servers and multiple storage units into a single high-availability cluster, RXD1215sas delivers unyielding reliability and data availability. With the active/passive structure, services are automatically switched over to one server if the other unexpectedly goes offline, helping your business avoid costly downtime.
Synology RackStation RXD1215SAS - hard drive array - TAA Compliant
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
48 TB
SAS
12 (installed) / 12 (max)
Supported Drives
SAS
Storage Controller
RAID (SAS) - RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 4 TB HDD - hot-swap
AC 120/230 V - 50 - 60 Hz
Power Redundancy
TAA Compliant
43 cm x 69.2 cm x 8.8 cm
18 kg
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SAS
Storage
48 TB
HDD Array External Interface
SAS
Storage Controller
RAID
Interface Type
SAS
Max Storage Devices Qty
12
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
12 x 4 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS (input) , 2 x SAS (output)
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
248 Watt
Power Provided
500 Watt
43 cm
69.2 cm
8.8 cm
18 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
